skydragoness »
https://forums.nicoclub.com/skydragoness-u193.html
Tue Dec 07, 2004 3:38 pm
I'm surprised no women have contributed to the thread.
I used to use the pill for b/c, now i use the nuvaring... SO MUCH EASIER TO DEAL with. Especially since i can't remember to take the pill every day so i switched. If your gf has just started the pill, like everyone said (you guys are well educated on the matter) it varies from woman to woman. You can get over-the counter ept tests to be sure, but i wouldn't trust them 100% either. Nothing's 100%. Best way to be sure about it: double-up. Use a condom and have her on the pill. It's the safest way.
The pill has come a long way since the 70's side effects are much less severe, esp. if the woman doesn't smoke. The nuvaring i'm using has the same low % as the pill does. I do highly advise to stay away from the patch, it's evil. Because it has to deliver hormones through the skin it is 10 times more concentrated than the pill and the ring. It can cause certain problems in women.
Anyhow, hope that helps. I'm quite the advocate for b/c. No one should have a kid if they're not ready.
