blownhemi »
https://forums.nicoclub.com/blownhemi-u134237.html
Wed Oct 09, 2013 11:44 pm
What injectors and MAF are you using? I have perfectly good idle with 1000cc and the E60 MAF (pink?, RB25DET late or RD28), and the stock 52 VQ cell program, with the E60 VQ table just copied in (except the bottom 12 cells).
But actually, that's beside the point, because you don't need the sub 1V range to tune your idle.
You need to tune your *injector latency* to get a good idle.
Injector actual open time = injector latency +Theoretical Pulsewidth (approx. from fuel correction table)
The injector latency is constant throughout the rpm+load range. But TP varies, and it increases with rpm+load. But at low rpm and low load, TP is very small compared to the latency value, so small, that it barely influences anything at that point, it is mostly dictated by injector latency. The bigger the injectors, the bigger their latency, and the smaller part the TP plays in determining your actual final injector pulsewidth.
I'm 99.9% sure the ECU does not use the VQ+fuel table for idle (TPS idle switch), it uses closed loop. I'm basing this theory on the experience, that no amount of fiddling around with open/closed loop and fuel correction values has fixed my lean idle. Then I read somewhere (ECU2.forumwise, probably) about the latency/TP/idle relation, and it all made sense. We pushed up the injector latency, BAM!, perfect AFRs at idle. (meaning the usual closed loop AFR hunt around 14.7, but still better, then 17+s, as before)
I still think a ROM tune is the cheapest, simplest and best value option, and perfectly adequate for 350 whp, if not more. You just have to have some understanding of how fuel/timing control works in general, so you don't blow up your engine. (And by far a more elegant solution, then piggybacks, I think.)
