Pwnin O’Brien wrote:
There's no fitment difference between the LE and SE. The grille will fit on both.
seller stated that you need to do some cutting and grinding off your stock grille. i can see why you need to remove the emblem but to cut and grind some other stuff is beyond me
edit :: yep, just the emblem needs to be removed and maybe a little grinding down on the LE not a big job at all.... ill be getting mine in the next coming week once payroll comes in
Modified by Innovazn at 1:02 PM 2/9/2010
