chad_KAT »
https://forums.nicoclub.com/chad-kat-u27006.html
Tue Oct 09, 2007 3:57 pm
Well im on my way with buying all my stuff for my KAT setup. So for i got my Intercooler kit, tial bov, 38mm tial WG, jgs turbo kit, fuel pump-injectors and reg kit, and a few other things but as of now im looking for something to tune with and i think bikirom is a awsome way to go. I will not have a problem installing the board from previous soldering skills.
Any ways im running a 96 manual obdII ecu in a 98 s14 that was converted to manual. I was on bikiroms web page and seen that they want you to use a 94-95 ecu i belive.
I want to clarify that this is only obd 1 compatible?
If so will there need to be any wiring harness changes at my ecu connector? iv all ready switch 2 or 3 wires around because of the auto-5spd swap.
And if i need a 94-95 ecu does it have to be manual? and where would be the best place to find one.
oh p.s my car is in the body shop because here in Michigan we have these bastard things we hit in cars called deer. they only seem to run out at the worst possible moment, or you just don't even see them at night (in my case) thank god for AAA full coverage as all the damage to my right front corner is being replaced/fixed. no structural damage just fender bumper and partial hood. it had bad hood chips anyway so whoohooo for that i guess. but thanks for reading my stuff any help is grateful.
