so this is basically a new thread that is stemming from another thread because the bikirom was mentioned there and the higher powers have decided that it is definitely worthy of everyones attention.
here's the old thread:
zerothread?id=110002
and here's some information that has been posted so far:true, the 89/90 ecus just require a zif socket for like 3 bucks lol, but if your considering going to jim wolf, consider again... its WAY expensive, try
http://www.bikirom.com the megaboard isnt out yet, but will be in a matter of probably a week or two... and will be ~150 bucksHeres a break down of what you need to know.
B13's and S13's share the EXACT same motherboard. What this means is that your ECU uses the EXACT same traces to get its information from the built in memory as the B13 SR's and S13 SR's. So, the product that your looking at on biki's site will work for the OBDI KA24DE (91-93).
Im using a B13 daughterboard on my KA and it works fine....Cost me $100 and now I have a fully reprogramalbe ECU. Dont forget though that you will also need an EPROM burner. Mine was $150, but, mine is also overkill. You can get a reputable burner for like $85 (Willems).
S14's use a different board, so its highly unlikely that this would work on them.
All said and done, modding your stock ECU with a daughterboad (exactly what JWT does only they use a single 16bit chip with scrambled code, which I have and is de-scrambled) will cost you about the same as a full E-Manage set up, or a plug and play JWT set up.
Cost break down:
$100 for a DB, $85 for a burner, $350+ for a wideband O2 <--because tuning with out one is pointless.
The beauty of it is that you will NEVER have any downtime, shipping costs, turn around, or, pay for an miscelaneous reprograming due to part upgrades like MAF/injectors/revlimit changes etc....I can do a write up, thats not a problem.
Theres several other boards available, most of which are cheaper than Biki's newest boad, but, the Biki board looks uber more versatile than the others. Seriously, that guy and the guy I bought my board from are pure genius. They could shed a TON more light on this subject than I could.
But, Ill start a write up, and hopefully the educated lurkers will chime in.
EDIT: It may take a while before I can post it though. Its just a lot of info.tuning site:
http://forum.ztechz.net/Its a good site, Ive learned a lot from it.....still havent registered an account there though.
Do a screen name search in the 240SX section of that site for a guy named Calum. He knows his stuff. Im currently using his board.
Heres another cool site that you may be interested in. Its for a 300ZX, BUT, it gives you all the basics you need to know in terms of reading code and tuning your ecu. Although our boards require a more complicated chip set up than the 300ZX example on that site.
The mother of all Nissan ECU tuning links:
http://cherrypicker.tripod.com/id10.html
that's all so far... and there's a write up coming soon from someone hopefully... i think it was jrl that said he could do it but it would take time. definitely appreciated.there is tons of information on these sites, so if you are interested in doing your own ecu tuning, or just curious as to how it works, or want any information at all check out these sites:
http://www.bikirom.comhttp://forum.ztec ... /id10.html
more to come soon hopefully.
