biggest tires for 350z rims?
purestock240
Car: 240
hey i am thinking about buying some 18 x 8 Aluminum Alloy 350z RIMs, 5x114. Bolt pattern, +30mm offset. what size tires could i run? and what would the fitment of the rims be like?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Me..... Id run a 255 on the rear, and a 215 on the front, 255 40 17 and 215 45 17, but that's me. Depends on how you use it, do you want spacers and a stretch, as much meat as possible, stock look. It's all up to you papi
purestock240
Car: 240
i really dont wanna run spacers, so as they sit what would the fitment be. as for stretch im really not into running alot of stretch
kouki munster
Car: 97 base 240
post4938332.html#p4938332
Check the pics^, 225/45/18 on the front, and 255/40/18 on the rear, no spacers. You can run some 265/40/18 on the rear if you want, but they will rub just a little depending on ride height.(10 minuets with a fender roller will fix that)
I wouldn't go any wider than 225 on the front without dropping the the sidewall to a 40 series.
LOVERboy
Car: 1997 240sx se KAT
i had 275/35/18 in the rear .... spooled got those wheels now ....
Dazzla
I run 225/45/18 up front and 245/45/18 in the rear.
45 sidewall is way to big on these, I'd stick with 40 if you can. The highest your suppose to go on these wheels is 265/35/18.
Their +33 but they clear my coilovers by a few mm.
