biggest socket size on the 240
Juujai
whats the biggest bolt on the 240sx? i just got a tool set and i dont want to get mad when i find out i dont have enough sockets i have 1-21mm tried searching
azncorruptedo17
Car: 1991 Nissan 240sx SE
should be up to 21.... you mostly need the 10 12 and 14 =] not sure but i think there's a bolt somewhere in the suspension that maybe a 23... not sure though, haven't touched my suspension for a while...
Juujai
thanks now i need a torque wrench those things cost too much =/
Revat619
Car: 97 240sx
yeah the can be a bit pricey i guess, but they're such an awesome thing to have. For what it does, i think it totally justifies the cost.
sxseguy
Car: Makin' it go faster!
The hub nuts are big. 36mm, I think.
rawill240sx
Car: 1990 240sx
I think the biggest on the engine is 1 1/8th or 1 1/16th of inch on the bolt that holds the crank pulley on.
biggie
Crank Pulley bolt is 27mm.
Thought the hub bolts were 19mm. Not sure on that one.
crzycav86
Car: 93 Nissan 240SX KAT
sxseguy wrote:The hub nuts are big. 36mm, I think.
Yup. These are the big nuts that attach the axles to the hub... the biggest ones i've seen on the 240sx so far.
The most common ones for the suspension/brakes is 12mm, 14mm, 17mm, 19mm, 21?(LCA ball joint nut, not sure about the size), and 36 for the axle nut.
xekushnr
Car: '90 Nissan 240SX Hatch
Juujai wrote:thanks now i need a torque wrench those things cost too much =/
i just purchased $3800 worth of tools from Snap-On. now that cost a lot :o
come to think of it, i think i still need to get a torque wrench. damn.
Juujai
damn ur hatchback better be that crazy lol 3800 worth of tools that crazy i think sockets from 1-30mm in deep and regular tons of ratchets and extensions sounds good and of course the torque wrench and impact driver
anyone know if we need tons of wrenches or will the sockets fit in most of the places
a while ago before i had tools we used everything lol vise grips tore everything off for us it made a 5minute job become an hour what good is a man without his tools
Juujai
i like craftsman tools because i dont have to hold back using it lol if i break a ratchet or 2 i just headback to sears and get them to repace it i dunno about snapon cant afford
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
my $100 craftsman socket set had every size i have ever needed with 3 exceptions: the front and rear hub nut (22 and 32mm if i remember right? maybe its 36 like the guys are saying) and a 20mm extended socket to adjust my parking brake.
gumby
Car: '89 240sx sohc
27mm = 1 1/16
kane2g
Car: 92 240sx 95 240sx
32 is the size of axle nut on s13i beleive s14 uses 36
Where did you get 1mm socket???
doohopark
Car: 97 240sx
um if you mess with cams a alot you need a 26mm wrench and a 21 mm socket i think, for got, i have my tools seprated into kits, like engine kit, suspension kit, interior kit, craftsmen tool are cheap so i go buy multiple set when they have sales. it makes it so much faster when working on something, cuz i have a lot of tool and digging through them is very annoying.
Nismo_Freak
Car: 89 Nissan 240SX
kane2g wrote:32 is the size of axle nut on s13i beleive s14 uses 36
32mm front - 36mm rear on the axle nuts.
98s14inaz
Car: 2010 Nissan Titan Quad Cab
Rear axles are 36mm. That is the biggest I have seen so far and I have tunred nearly every nut and bolt on this car.
xekushnr
Juujai wrote:i like craftsman tools because i dont have to hold back using it lol if i break a ratchet or 2 i just headback to sears and get them to repace it i dunno about snapon cant afford
snap-on is the same way. lifetime warrenty on every piece in my set, so if in like 30 years a socket strips out i get a new one for free
98s14inaz
Unless, although highly unlikely, they go out of business.
BoostFab
Car: S13cp, S13fb, S14z
i would say 36mm (rear axle nut) is the biggest one.
andrave
Car: 1989 Nissan 240SX Coupe
yeah but those are so expensive and you need them so rarely. If you were just trying to build up the commonly needed tools I'd leave that one out. Myself, if I need to mess with them (took front hubs off once) I just borrow them.
Juujai
my bad its not a 1mm i think the smallest i have is a 5mm
andrave
hmm, has anyone seen my deep 17mm craftsman socket?
defintely my most commonly used socket, and its missing....
