fo0manchu wrote:would this allow the engine to rev higher, since the head is more free flowing now?
Revving higher rarely has as much to do with more flow as it does being mechanically able. You can get higher lift cams to get more flow. Some of the limiting factors to revving higher tend to be valvetrain weight/spring stiffness, poor harmonics/balance, not enough oil flow at high RPM's to keep pressure to the con-rod bearings, and con-rod tensile strength.
