Hi, I did some searching on the forum (I'm a newbie here) but could not find an answer.
What would be the biggest tire size that could work with OME lift with no wheel spacers and minimum trimming? There have been some posts on the AC lift and tires, but I'm running on OME. Right now with 255/70 R16 (about 30") the rear tires already will occasionally rub the inner fender (on BIG dips), maybe I need new wheels with more backspacing? I'm using stock R16 wheels now, no idea what backspacing is on these. Fitting 33" on AC lift does require spacers to fit front tires under struts and heavy trimming (according to this post
post5614709.html by ruggedpathy), so that would definitely be above the upper limit.
Thanks for your help.
Infiniti QX4 '99
OME lift kit
