elwesso wrote:......As we know, the front bar is 1.4 times bigger than the rear bar (28mm/20mm=1.4)....
What would happen if we had a set of sway bars that were a little bigger.... Using the same proportion, we could run something like a 26mm rear bar and 36mm front bar.......
I remember tech saying that you dont want sway bar stiffness to exceed the spring stiffness..........
Maybe we can find the 24mm Stillens and just have the fronts that would be 33.6mm custom made.
Here's some older "tech" info on sway bars and body stiffness +.....
I got it from the archives. It was all crunched up and I tried to break it up a little so it's easier to read.
We have tried every combo on customer’s cars and my own.
You must visualize roll stiffness and get away from absolute values.
The Q is 55/45 weight distribution empty. This is far from ideal, the extra 200 lbs. means front springs must be a 5% stiffer and the rear 5% weaker for it to sit level. To avoid a pitching movement on the highway the rears are actually about 18% weaker so the rear bobs up and down at a very slow rate as this generates the lux ride most people are used to.
The 29mm [170 lb./in] front bar and 166 lb./in front springs vs. just 122 lb./in rear springs means that over 75% of the roll resistance is in the front so the rear rolls 3" for every 1" the front does. A 20 mm rear bar acts like a 50 lb. spring side to side...so the rear roll acts like 172 lb. springs side to side. The front is still very stiff but the rear redirects some of the roll to the front now but only 50 lbs. more worth which is miniscule to the 330 lb./in front stiffness. A 28 mm bar is 13% less stiff than a 29 mm bar. divide by 2 since the springs and bar were equal before so the front would be 6.5% less stiff and the rear would be 41% stiffer. But his still means rear roll just half as much. A race car might be almost perfectly balanced with 50/50 weight and 52/48 roll stiffness. A 29mm front and a 20 mm rear is close to 66%front vs. 75% with no rear bar. You almost split the difference between...75%factory.....65...... 55%professional racer This is a very safe ratio that won't get you into trouble in rain [with proper tires] because the Q has loads of rear traction except when you accelerate in rain....as you know from experience. Remember you have a viscous limited slip which if not worn out will also help out. 13931 When you add a rear bar you must take the car to a parking lot or track to safely understand what the change does especially in the rain as you are unconsciously aware of what to do with the stock car in an emergency
. Up to a point the 20 mm bar will give you added confidence in normal emergency maneuvers but your stock shocks in rear will not be able to control the extra stiffness [they are set for 122lb/in springs not 172lb/in springs and bar in a turn with rapid back and forth movement. It is almost impossible to ride in a car which has the shocks stiff enough to fully control a super [above 22mm] rear bar as they won't move in straight ahead highway driving. The Tokico HP are only 15-20% stiffer than stock [or still 25% less than the 20mm bar needs] and these are noticeable on highway and about all most people will tolerate on a 8 hour trip. When you install the bar please upgrade your rear shocks or at the minimum install brand new factory rears! Remember the Q45A has this 20 mm bar but the shocks are set assuming the bar not so in standard or "t" cars where the 15.9 mm bar is only 20lb/in [barely know it's there so no stiffer shocks are required]. Note even the "t car" will wear rear stock shocks faster due to the bar...so they need replacing about every 50k vs. 60k on a standard Q.
All 90-96 Q have the mounting holes for rear sway bars --the available sizes are 15.9 mm from "t" and 20mm from "a". Whenever a rear bar is fitted the front bar is reduced from 29 to 28 mm. The Stillen solid rear bar is 24 mm and should be considered for racers only due to harsh impact and oversteer in rain!!!!!!
All years "a" have the 28/20mm bar. The 122 lb./in rear stock springs are soft for a lux ride ,the Eibachs are not that much stiffer [15%- 25% progressive] and the addition of the 50lbs resistance of the rear bar helps some but before the front springs consider the 24 mm Stillen bar [for expert drivers only-- much wet snap oversteer] as the extra 100 lbs. will further limit the rear roll. You can use some combination of rubber and the provided urethane to soften the first inch of impact harness but remember the wheel moves four inches for every 1" the bar moves [if rigidly mounted] more wheel movement if rubber is used. The factory supplied 20mm hardware does not allow the bushings to be compressed so there is little happening with the bar until the wheel moves about 2".....you must use metal washers between all the rubber bushing where they touch the bar on end links or replace with urethane/nylon bushings. To avoid deformation of bushing! Same as you did to front bar.
Enjoy!!
