Bigger Radiator?
aaronselite
Car: 2001 Pathfinder LE 3.5 V6 Auto 4x4
I just noticed that the stock radiator is only less than an inch thick! Most, if not all, of my off-roading is done in sand and will usually overheat when I do. Thankfully I only off-road about a half dozen times a year. The 2 radiators I'm looking at are from C&R and Mishimoto. I'm particularly curious about the transmission cooler since my Pathy is an automatic and Mishimoto does have one that goes with their radiators. Has anyone ever put in a bigger radiator in their r50? Any info would be helpful since this is something that I would love to upgrade. Mahalo!
m0nkeyprince
Car: 1998 Qx4
i dont think a bigger radiator will do much, an external ATF cooler however, is a different story, the cooler your ATF is, the longer your transmission will last, and transmission repairs are pretty costly :P i have an external ATF cooler by B&M, comes with brackets, hoses, bolts everything, for only 60 bucks, its a hell of an investment.
EsotericImage
Car: 99 Civic on 10lbs boost
02 Pathy as DD
A dual core would help the cooling.. I didnt know Mishi had one for the pathfinder....
60 for all the components AND the trans cooler is a hella-deal! Link?
*edit*
you might have to use 2 electric fans and delete the OE fan.. you can hook a relay up. But dont buy those cheap mishi slim fans. they are the same as cheap ebay fans with a 50.00 mishimoto sticker.
Xenocron.com has Maradyne fans that push up to 1500 cfm. 2 of those bad boys and your over heating blues are over!
Pwnin O'Brien
Or you could throw two of these bad boys on your radiator. They're 3,300CFMs each.
EsotericImage
02 Pathy as DD
