Bigger oil filter
seang
Car: Ford Fiesta ST
BAD THREAD, DO NOT READ BEYOND THIS POINT. This is coming from the author himself. I thought that a motorcraft FL1 filter would fit my truck, and it almost broke the oil pressure sender right off my truck, which would have caused me a great deal of grief. The filter that DOES fit is called a PH2870A, and it's for a VW 1.8T. It's a little longer than stock, but the same diameter canister, and with the same threads and o-ring size. This filter works great. The PH2870A is Fram specific, but I'm quite sure that other brands would also designate this size using the numbers 2870. This could be cross referenced, (online perhaps), if one would want a brand other than Fram.
Modified by seang at 12:13 AM 10/16/2009
Modified by seang at 12:15 AM 10/16/2009
Q451990
Don't do it! Your truck will see that "Motorcraft" logo and puke the filter off out of spite!
seang
Car: Ford Fiesta ST
I'll just drop some prozac down the oil fill
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Our filter thread dimensions are 3/4-16 and shared with Volkswagen and Subaru. Also some Ford vans use the same filter.
S133P3R
Car: 1989 S13 240sx
wandered in from 240 gen chat...is there any difference in the oil filter threads on the 240sx Ka-e vs the truck Ka-e? i wouldnt think so but if anyone knows for sure lmk...thankS!
seang
Car: Ford Fiesta ST
Modified by seang at 12:16 AM 10/16/2009
PEZi
i like my k&n... its beefy and has an anti-drainback built in
S133P3R
Car: 1989 S13 240sx
PEZi720 wrote:i like my k&n... its beefy and has an anti-drainback built in
i think this diy:oil cooler from the tech pages (http://www.nicoclub.com/articles.php?id=167442) would be cool and you could do the oil reloaction part only and just use that huge chevy filter and then later build the oil cooler to ad to the system.
Rev_D21
KA-Truck and KA-240 use the same filter. Up until 96 most Nissans used the same '55Y' filter. In 96 Nissan introduced the smaller '9E000' filter which uses the same filter base, just a much smaller filter.
S133P3R
Car: 1989 S13 240sx
Reverend D wrote:KA-Truck and KA-240 use the same filter. Up until 96 most Nissans used the same '55Y' filter. In 96 Nissan introduced the smaller '9E000' filter which uses the same filter base, just a much smaller filter.
thanks
Q451990
So the 55Y00 filter would be OK on my '04 Frontier with the KA24DE?
Any idea what the difference between the two filters is, as in why would Nissan want to use a smaller filter?
Heath
Rev_D21
The '9E000' full name is 15208-9E000.The '55Y' full name is 15208-55Y00. I can only imagine that Nissan is getting a better filtration rate using the 9E000. Switching back to the 55Y might get you a little more oil in the system which will help battle heat a little bit. I have never tried it though.
seang
Car: Ford Fiesta ST
The FL1A did not fit on my truck
S133P3R
Car: 1989 S13 240sx
ooof!
