Bigger isn't always better
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
We are in the process of swapping turbos for a friend so he can stop when he needs to.
Moral of the story: Clearance. Boiling your brakes is bad.
S14toRPS13
This has always been a common problem when you decide to go top mount.
biggie
Biggier is always better, so says me.
Different manifold would also help.
mastakilla08
Car: 1992 hatch, 1989 piggy coupe, 1991 coupe silv.
Ya big is fine just get a bottom mount
breadbox
89 Koop
84 720 4x4KC
yeah trying to get him to just run a stock setup for now until he know what he wants to do. I want see what that turbo does on my KAe turbo manifold.
Silvia_Ks_90
Car: 1990 Silvia K's w/2JZ
2007 Subaru Legacy Spec. B Stage 2
Turbo blankey, manifold wrap, thermal covers for lines are just a few things that come to mind, but damn that is ridiculously tight fit!
breadbox
89 Koop
84 720 4x4KC
As you guys can see it rests on the brake line. IDK why they even mounted it and left it like that. I am in the classified seeing what we can replace it with right now. Got some good options ATM.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Many of the RB manifolds do the same thing when installing larger turbos on a LHD car. Solution was moving the turbo forward and positioning it where the downpipe would route away from the brake master...
btw this is a 3.5" downpipe, GT35R, Raw Brokerage manifold...
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
Turbo Blanket and wrap the back hose. Or you can make a shield around the exhaust housing of the turbo. This is what I have done installing my T70 Supra turbo. Believe me, bigger is better. :biggrin: ;)
Huh Tight fit....
Before
After
Lobo240sx
breadbox wrote:As you guys can see it rests on the brake line. IDK why they even mounted it and left it like that. I am in the classified seeing what we can replace it with right now. Got some good options ATM.
Get a custom manifold made. That will give you more room. It won't be cheap though. You buy a cheap Ebay manifold it will crack on you.
Gabes13
Car: rb20det s13
insert dope a** product HERE
PLUUUUGGGG!!!!
hahaha
