Dlauth wrote:I just bought some 370cc injectors for my future turbo setup. I was wondering if I could install them when i get them or should i wait until i get a FMU? Thanks
lol
you cant just toss them in and expect all to work out. If your o2 sensor is not in real good shape your gonna be so pig rich you would be able to drive in the low throtle areas of the map. And the fmu will only supply X amount of extra fuel pressure per psi of boost(unless your gonna shell out the like 400 for the missing link(vortecs "tunable" fmu(proportionate to manifold pressure) but if you gonna go that route, real fuel control could be had for roughly the same price.....
the ecu has a K value that represents the afm and injector size, changes to the afm or injectors and not the k will result in problems. I mean folks have hacked to get the injectors to work with stock ecu but it can be troubles......
