Bigger injectors
vboyq
If i were to buy bigger injectors 550cc injectors would that affect daily driving mileage or only open throttle driving, also how much mileage can be expected out of the 550cc injuectors on about a 10psi daily driven t25?
yellow_jacket
Car: 95 240sx
Theoretically, yes your fuel economy will fall off. Reason being that the ecu can't control the larger injectors as precisely. Fuel economy will vary widely depending on the driver and the condition of the motor and electronics.
vboyq
would it be a major drop off?
Silviagirl79
Car: I love Silvias, Skylines, Soul Calibur II, and GT3
get a z32 maf w/plug. And get your ecu reprogrammed or an afc
yellow_jacket
Car: 95 240sx
What will probably kill the fuel economy most of all is that you will want to get on it more. If you stay off it you should run about the same fuel economy as before.
vboyq
So then it will noticeably affect the fuel until i drop the hammer?
hokiruu
Car: 2012 INFINITI M37X Platinum Graphite
'95 240sx/s14 SR20DET (in 2000) SOLD
NO, he said it will get worse when you drop the hammer. More boost=more fuel(hopefully). Makes sense right?
vboyq
yeah it does, but what asking is during normal driving w/ partial throttle, will it significantly affect the gas at ~10psi
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Normal cruise driving with light throttle, you won't be in boost to begin with. Does that answer your question?
vboyq
o ok i get it nowTHANX to all!
lifeofshadoze
will the ecu need to be reprogrammed to utilize the larger injectors?
yellow_jacket
Car: 95 240sx
yes
