actually you might not see that. depending on how your tuner changed the map he could've divided all the injector cells by the factor. sometimes i keep the correction at 1.000 and just multiply the entire injector map down a percentage.Darius wrote:You need to change your injector correction factor if you or your tuner hasn't done so yet. Since the stock injectors are 370 cc and you put in 660s, you need to reduce the correction factor by the direct proportion of the two. 370/660=0.56 So, if you don't see that number somewhere, something was set improperly.
You need to change the value to a 56% of the actual value, in all the table.Tripz wrote:Thanks. How would I go about doing that and what value to put it at??
Your plugs are probably fouling ,caused by a very rich AFR , or the gap is too much, the gap would be around 0.6-0.7 mm , specially if you have the stock ignition parts.Tripz wrote:The car is starting to backfire and is misfiring at WOT. This happen'd before at the dyno shop, then we changed out the spark plugs and it made a clean run. Now it's happening again and I know its the spark plugs and probably weak coilpack, any input?
You need to go to "cranking" , this are the start cranking inj pulse, if you have bigger injectors you need to change this value , otherwise you will have starting issues, specially when the engine is warm.Tripz wrote:Do I change the table values in the inj map? Or what menu under setting do I have to go to adjust this valve so it'll be more easier to start?
