tenkawa_akito wrote:here's an easy formula for you.flow rate = (HP X BSFC) / (# Injectors x Maxcycles)
HP = no brainerBSFC is brake specific fuel consumption in pounds horsepower-hour (Normally this is 0.4 to 0.6 at full throttle. Assume 0.55 for turbo charged engines, 0.45 for NA engines)# Injectors. DuhMaxcycle is the maximum duty cyucle of the injectors. (Above 80 percent, some injectors could being to fibrillate or overheat, which could eventually cause the to lose consistency--or even fail completely)
So,on an S13 SR running an S14 T28, I don't see much more than 300 HP being seen, so we plug that in the formula.
flow rate = (300 x 0.55) / (4x0.8)flow rate = 165 / 3.2flow rate = 51 lb/hryou convert lb/hr to cc by multiplying by 10.5 (Thanks blake!) which leaves us with:flow rate = 541 cc
You will be fine with a 550cc injector. Going any larger is overkill and seriously hurts your economy.
flow rate = (205 x 0.55) / (4x0.8)flow rate = 113 / 3.2flow rate = 35 lb/hryou convert lb/hr to cc by multiplying by 10.5 (Thanks blake!) which leaves us with:flow rate = 370 cc
See how that formula is flawed? ... it fails to have a pressurized conversion as well as a real world aspect towards the SR20DET engine.
370cc injectors hit 100% duty at 270rwhp or so, and the stock MAF hits 5 volts around the same area.
The 550cc injectors will be able to flow 33% more fuel and support roughly 30% more power, however this is without factoring in the rail pressure. Meaning the 550's will be good up till about the 340whp range.
At a peak HP value of 270rwhp which is about the S14 T28's limit from my experience is gonna push duty cycles into the optimum range for the 550's.
If you plan to run this setup for a long time get the 550's, if you plan to run this setup for a short while then upgrade then get the 740's.
We have a VG30DETT engine that idles better than any SR I've ever heard using 740cc injectors. The idle is 100% up to the engine management and the tuners ability. With a S-AFC it's like showing up to a gun fight with a .22 bolt action and one bullet.
Motec M400 > *
