Hi guys, I was thinking about getting bigger injectors for my KA-T. I wanted 550's. Do I have to get an upgraded maf if I get these injectors because right now I have sr 370's and on WOT to get the AFR's in the 11's my safc hi throttle settings range in the -40% to -30%. So I would have to turn down the fuel even more but you can only go to -50% on the safc II. Will an n60 maf be good enough or should I get an n62 maf if I wanna run 550's? I do not plan on going over 300hp.
Any insight would be appreciated.
Thanks, Alex.
