I wish they made SC kits for our cars.EniGmA1987 wrote:Changing cams is completely pointless unless you are doing other major work too like going FI or other internal engine work.
It takes very little work to adapt a G35 supercharger kit to our car since the engine is the same and we actually have more engine bay space than the G'ssteelcity wrote:I wish they made SC kits for our cars.EniGmA1987 wrote:Changing cams is completely pointless unless you are doing other major work too like going FI or other internal engine work.
Cams alone with no other real mods to make use of the higher profile intake or exhaust timings will only add a very small increase in power while affecting other areas of the power band and possibly making the car idle rough. It will also cost north of $1500 to do which makes the entire thing worthless because there are better mods you can do that add more power for cheaper.LouCast wrote:Doing cams is not pointless, and you don't need it to be FI or internal engine work. Cams increase the top end power, making the power band extend further on the RPM band.
I agree LouCast. Definitely not worthless. Enigma is just saying that if you go that far, you might as well drop more into it. Has Fatboy been around? He knows how to go about that SC.LouCast wrote:Doing cams is not pointless, and you don't need it to be FI or internal engine work. Cams increase the top end power, making the power band extend further on the RPM band.
