C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sun Jul 29, 2007 8:46 am
All you would likely need is a time delayed momentary switch. I'm thinking it will need a ground signal, but you may need to confirm by testing it. I used a device called the NoNag, which was actually designed to bypass the disclaimer screen on the navigation system. I actually used it to turn on an xbox for me so I had contacted generatorlabs.com asking if they can make a specific model to my specifications. It had a 2 second delay and pulsed a .5 second ground pulse when the ingition was turned on. Something similar can likely be done once you know what signal you need to activate the switch for you. There are other ways, and perhaps cheaper ways to do this, but just throwing out some options/ideas. The NoNag is $59.99.
