Big trouble in little.... fuses?
scissors4hands
Car: 95 zenki =D
So today i got too drive my 240 around since i put in the ka and i drove it all day too see what worked and what didnt.
Well, two problems, one i have a slight hesitation when first taking off kinda bogs down then goes...
second, brake lamp and gauge cluster stopped working, i checked the fuse and oh dang blown fuse, did the ol' switch aroo and it blew again. (obvously bad circuits or wiring any help i searched but no one had answers)
Btw if you didnt know, its an 89 auto-tragic if that helps.
Any help or suggestions would be great.
"nissans are reliable "...pff my a$$... i kid i kid....
Dont let me go back too my rx7! muahha
scissors4hands
Car: 95 zenki =D
anybody?
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
the gauge cluster and light issue has been covered, greg posted a fix it in the tech section. the bogging issue, could be a lot of things, do a tune up, check vac lines, any check lights?
scissors4hands
Car: 95 zenki =D
srpowered240sx wrote:the gauge cluster and light issue has been covered, greg posted a fix it in the tech section. the bogging issue, could be a lot of things, do a tune up, check vac lines, any check lights?
i have a 13 and a 33, i did a tune up before i put the engine in, i also changed the vacuum lines before i dropped it in too.
and im going too check out that thread asap, i swear i looked though.
uselesswingsr4penguins
Car: 1992 s13 coupe
the bogging down thing could be a fuel management problem...id try changing the fuel filter and if that doesnt help you may have a fuel pump going bad, mine did similar things when my fuel pump went bad but the **** thats been in your gas tank for the past 15 years doesnt really burn very well in your engine during acceleration and if the fuel filter is clogged its not gonna allow the proper amount of fuel into the motor during an acceleration
scissors4hands
Car: 95 zenki =D
I changed the fuel filter too the z32 fuel filter and it cleared up the hesitation, it started too bog down super bad the second time i started it, when i gave it gas it would want too bog down an die, i turned it off and back on and it was fine. No hesitation though
the fuse problem is still scaring me, should i try too re-wire my car? any suggestions
scissors4hands
Car: 95 zenki =D
okay so now my car is bogging down when i give it gas an dieing on me, then not wanting to start.
i have a bad idle and hesitation problems.....
help please? is it the mass air flow sensor? fuel pump gone bad?
snwbrdr435
Car: 85 VW Westfalia, CBR F4i, SV650s, 1988 Honda Hawk(race)
i would check the mass air flow sensor sounds like that could be the problem cause it seems like your air fuel ration is getting messed up get some cleaner and see if that helps
scissors4hands
Car: 95 zenki =D
how would i check the mass airflow sensor, becuasei already cleaned it, but i dont know how to check it,
also too check the fuel pump would i get a fuel regulator?
2ndnissan
Car: 1990 240sx hatch
Sock filter on the pump could be clogged. I've changed pump and filters and cleaned everything in the fuel system. When it gets to an eigth of a tank or less ,I get the bogging and hesitation. I took the tank off and cleaned it some but at the bottom of the tank the sock filter still picks up enough rust eventually to clog. Eventually I'll need a new tank, until then I drive with at least half a tank and it's fine. Occasionally I'll have to clean that filter again too(just squirt it with parts cleaner till it's clear again). Could be your problem..you didn't mention fuel level when it happens...
scissors4hands
Car: 95 zenki =D
it has a full tank, i thought maybe i was running oiut of gas so i filled it all the way up and it still does the same thing.
