goofynick6 »
https://forums.nicoclub.com/goofynick6-u13220.html
Mon Aug 30, 2004 11:26 am
Ok, Sorry I've been asking for so much help lately, but I'm like at the end of my fuse on some of these weird problems!
Ok, the motor is running decently and boosting, but now the transmission is hating me.
Problem:
Grinding (loud grinding!) when I shift gears over 2000rpm. If I go to like 6,000rpm in 1st and push in the clutch, it'll start grinding (even w/o touching the shifter) and it's hard to get it out of 1st gear. Then going from 2nd to 3rd or any other gear, when you put the shifter into gear (feels like it's in gear) it starts grinding and sounding bad, even with clutch depressed all the way.
What I've done:
1) Adjusted the clutch pedal for maximum throw of the clutch slave cylinder2) already bled the clutch line3) Stainless braided clutch line4) No dampener on the line5) Yes, I did put fluid in6) Got underneath and watched as someone pressed the pedal and watched the slave cylinder move in and out7) Found that double clutching and rev matching helps a bit, but still can't go at high rpms8) Torqued the clutch and flywheel according to spec and procedure
What's the setup?:
XTD Clutch off ebay for NA 300ZXFidanza Aluminum flywheelThrowout bearing (new) for s14 transKA clutch forkStock RB pilot bushing
So...I'm dying to get on this thing and go through the gears, but it just screams and sounds horrible. I'm not sure if it's a gear grinding sound or a really bad T.O. bearing sound, but when I rev the car hard in neutral and push the clutch in sometimes it makes the grinding noise.
ANY ideas would be great.
Thanks,Nick
