Sounds like time to tub the rear.craizg35 wrote:The rears are 12 wide and the fronts are 10.5 wide.
One of the benefits of tubbing is that it helps maintain straight line stability while enhancing cornering due to the greater adhesion. The biggest issue I see with the much wider tires would be in the area of hydroplaning but then I would probably keep the critter home during these periods of wetness.audtatious wrote:No need to tub it when you install a wide body kit as the wheels simply stick further outward.
Poyzinous wrote:you can probably use 26" rims. You have limitless vehicle potential, as I see you drive an Infinity.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
