Big T28
Neejay
I was wondering if anyone had any experience with a Big T28?
They upgrade the compressor wheel, turbine shaft/wheel, and machine/port a stock T25.
I bought a blown sr T25 (oil seal) for $50 shipped, and then they'd basically rebuild + upgrade it. I've read they're good for 340-360whp.
WDRacing
Without the specs it's impossible to give any input. Is it similar to a GT series? Such as the 2876r or similar?
WD
Neejay
WDRacing wrote:Without the specs it's impossible to give any input. Is it similar to a GT series? Such as the 2876r or similar?
WD
I mostly only see DSM Big T28 upgrades, but I specifically emailed a company that will do it (sr t25) for $625. The only thing I know specifically is: "Big T28 Compressor Wheel rated at 34lb/min or 340hp". But like I said, I'm not sure how well this would do on a KA-T as opposed to a DSM.
AGP's site claims they upgrade T25s to "TB03 compressor stage rated at 36lbs/min" which I guess is about 360hp roughly.
I was just more or less curious if anyone had used one or not...
Tx-Sx-FS
Car: S13 KA-T
just swapped to T28 from t25 but this sounds interesting, my seals were on the way...but if i keep it and able of upgrading internals for more power than the t28 i might keep the lil bugger
Neejay
Tx-Sx-FS wrote:just swapped to T28 from t25 but this sounds interesting, my seals were on the way...but if i keep it and able of upgrading internals for more power than the t28 i might keep the lil bugger
Yeah, I'm definitely going to do it. So I guess I could be a guinea pig :D
lrb_2000
Car: '91 Nissan KA-T hatch
seems like a lot of money.. why wouldn't you just spend the $625 on a better turbo? I guess it would be interesting to see though.
Neejay
lrb_2000 wrote:seems like a lot of money.. why wouldn't you just spend the $625 on a better turbo? I guess it would be interesting to see though.
Yeah, I actually decided to go with a Garrett T3/TO4E .48 a/r + JGS kit w/ wastegate. The garrett is $575 shipped (4-bolt discharge).
WDRacing
Excellent choice, very little lag matched to a great compressor.
WD
