DanielIser »
https://forums.nicoclub.com/danieliser-u13807.html
Thu Jan 13, 2005 5:22 pm
Ok, so i just finished installing a GT25R a/r .86, tubular manifold, and split dump pipe. First thing i noticed when i first started it up was its a lot louder and there was a noticeable exhaust leak. Well i fixed that and it sounded good to me. When i first drove it, it didnt pull at all. The HKS actuator i put on is supposed to be at 11psi correct? well the boost gauge never goes above 7 and that is a spike. It doesnt even feel like a turbo car at all. Pulls like a N/A car does. and doesnt pull all that good even then. I thought maybe the wastegate is opening too soon, so i put my MBC on it and set it to about 12psi, or where 12 was on the stock turbo. I made one mad dash to see if that took care of it, but it still barely pulled which lead me to believe maybe not enough fuel for the air. Well then I turned around to head back to the house and it was spitting and sputtering and wouldnt go above 2k rpms. Barely got it to 2k at that. I also noticed black smoke coming from the exhaust. Black smoke is usually a sign of running rich but the car doesnt run like that. It is running exactly like it did when my last fuel pump burnt out and i had to replace it with a walbro. Is my brand new walbro going out on me or is it not getting enough air from the turbo from a boost leak or something and getting flooded and bogging from to much fuel? Please help ASAP!!!
