the forsaken »
https://forums.nicoclub.com/the-forsaken-u38529.html
Mon Jun 19, 2006 4:17 pm
Ok I got a major problem with my electricity while swapping form my old ka24e to a ca18det. The car just will not start. I’ve managed to wire the fuel pump directly on the ignition switch. But still my coils and injectors won’t get any electricity. I must say I did not swap the rest of the harness I only got the engine harness and the part that comes from the igniter, I got the injector resistor, and igniter. I have also build an extra relay in the box, because the ka24e, does not use an ignition coil relay. The whole problem is in the part where the engine harness connects to the rest of the harness. I even tried to connect a + wire to one of the +wires of the coil, because when doing an sr20det swap, and you don’t have the whole car harness, you just wire the fuel pump directly and add the + wire the a coil or injector, and it will work fine. If anyone has done this swap the way I’m doing it please let me know how can I solve this problem. My car has been like this for 2 months already, and it’s driving my nuts. I have an other problem with the turbo but I have put it in an other threat. Look for it if any one can help.
