BIG PROBLEM!!!!!!!!!
IcanDoIt240
Car: 91 nissan s13
I just did the sr swap on my 91 and when i plug the battery in everything turned on with out the key in the ignition! does anybody know what the problem maybe i know the car did have an alarm in it but i ripped it out because it didn't come with any remotes
godrifttoday
did u do ur own wiring?
IcanDoIt240
Car: 91 nissan s13
yes i did my own wires and i fallowed the FRSport tech page i just think it's really wierd how everything is happening like this
sidewayspassenger1990sx
Car: 1990 240sx coupe
alarms love to do that...but check to make sure everything is connected and look at where your motor harness connects to the dash harness and make sure its all connected.also make sure your lower body harness is all connected, (3 on alternator,2 on starter) and check your fuses.
IcanDoIt240
Car: 91 nissan s13
ok so i found out when i unplug the grey plug by the battery everything stops acting the key is iin the on postion! so i fallowed everything fr-sport and nico said to do and this problem has happened i'm just wondering if anybody else has done this and had 7 wires left over.
IcanDoIt240
Car: 91 nissan s13
i have pictures but i can't get them uploaded for some reason!
the grey plug on the fuse box? and 7 wires? what do you mean?
IcanDoIt240
Car: 91 nissan s13
7 wires arn't used between the brown and grey plug on the left side next to the battery!
whaaaa???? lower body harness? ther are 2 that go to positive terminal than i think 4 that go to fuse box..
Kalypso
weird... take off your dash and check the ignition wires taht go to the lock.
get a wring diagram and get familiar.
you'll track it down, worst case scenario replace sections of harness. with new harness from other cars.
IcanDoIt240
Car: 91 nissan s13
how do i get pictures on here!
Marvelous_101
Car: '95 240SX SE & "91 Sentra SE-R
Do you have your engine grounded to the chassis? I had the same issue, I put on 2 ground wires from engine to the body, problem went away. Also you can check your ignition harness in your steering column.
