big problem
TST-240sx
Car: nissan 240sx coupe 1991
i just got my oil changed i have a 1991 240 with a ka swapped from a 94 s14.i was running my car against my friends car and the car was not pulling at all.the rpms were going crazy but my car wasnt moving much . but the car pulls from 1to 3 rpms then when i step on it all the way rpms go up and the car goes no where that happens on 1 2 3 4 gear. 5th is not too bad please help thank you
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
clutch..start there..if ya have power and cant move..thats normally the issue..good luck.
TST-240sx
but i just installed a new clutch like a week or two weeks ago
blknblu
Car: 1995 240sx base, j30 lsd, altima fans, cat back, ruca's, springs
liquid_cool wrote:clutch..start there..if ya have power and cant move..thats normally the issue..good luck.
it's the truth. sounds like the clutch is jacked up. I smell somethin' burnin' !
180weaver
Car: 90 240sx
when you installed the clutch, did you adjust the pedal play? It could still be in the break in process too
mychalous
Car: '96 240SX "Silvi"
180weaver wrote:when you installed the clutch, did you adjust the pedal play? It could still be in the break in process too
and racing against your friend isn't helping. YOU HAVE TO BREAK IT IN!!
