big problem
kod240kat
Car: 1991 nissan 240sx
wats up guys, my 91 ka24de the ecu is basically telling my injectors to dump major fuel. i am running rich like crazy i am talking 5 to 10 mile per gallon. i check the signal coming from the ecu to the harness connector of the injectors it check out ok. i was thinking maybe my coolant temp sensor is telling the ecu that the engine is cold when is not, but that also ok. now i am about to check my evap, vacuum test. my mass air flow connector and the ecu connector for it i think its pin number 26 (both volt and resistance). if any one is familiar, please post!
thanks
DALAZ_68
Car: 90' 240sx CA18det
have u checked for codes...
kod240kat
no codes present.
nismopu
Car: 1987 Nissan 300ZX
1997 Nissan Maxima
1976 Datsun 280Z Turbo
It is most likely your fuel pressure regulator thats causing the issue. I had the exact same thing once with a 240. went through the exact same diagnosis as you did as well, but when we swapped out the fuel rail it ran perfect. One to two psi of fuel pressure makes a HUGE difference trust me. peace.
kod240kat
i am about to test the regulator and get back to you
kod240kat
it came out bad i did a vacuum test and everythingnow you say you replace the whole rail, why?i am going kat if i do is the same oem rail good
