well there are only a few things that it could be. fuel, spark, or compression.joe3180 wrote:ok...i need to know some possible causes why my car would be runnin on 3 cylinders....any ideas? car runs but not very smooth. has no real pick up and go. i know its the second cylinder thats not working or is not working right. what tests can i do? what could be wrong? ill be thankful for any help. thanks in advance. please ask anything that might help too
Wait what? Please elaborate on this.joe3180 wrote:im sure it has fuel since after my little accident with det the 2nd cylinder was flooded with fuel
with your fuel pump fuse pulled out and no fuel pressurepull a coil pack off, stick a screw driver into it, hold it close to one of your valve cover bolts, have someone crank your engine over, see if it sparks.joe3180 wrote:fuel injectors are good...no leaks and pulse is good
so only thing left is the spark so im thinking coil pack...any comments? ideas? suggestions?
how would it not be safe?joe3180 wrote:thats safe?
joe3180 wrote:very high volage going through the screwdriver. its a bit scary for me cuz i already had some lower volage go though me before so im careful when it comes to messing with that kind of stuff
its DC current. its AC that ****s you up. I used to be an electrical technician. It will not hurt you. I have done it myself many times. and btw, its the amps that hurts. not the voltage.joe3180 wrote:i just know the arc is bout 10,000-30,000 volts so i dont know how much is commin from the coil. so if the current is going stright on through how do u get the spark?
