BIG PROBLEM Oil coming out of my blowoff valve!!!!
Sleeper415
Car: 240sx
Iv got oil coming out of my blow off valve and around the edge of my piping that go's in to the turbo so im kinda thinking my turbos f***ked i need to know??? and if thats the case does any body have one for sale
i have a s13 redtop with a stock garrett turbo on it if my turbos gone im looking for another stock turbo or a an upgrade depending on whats wrong with my turbo and the prices of the other turbos...
EazyBreazy
i would say your turbo is shot. pull it and check for play in the shaft and all that
S13FASTBACKSR
Car: '92 Fastback SR powered
i dont think you need to worry the same thing happened to me for about 3 to 5 days and stopped..its just blowby from your engine via your oil catch tank hoses...if you have your factory oil catch tank hooked up then it happens ...did it just recently start happening? and if so is it a ton or just a little bit? just wait about a week or so, dont freak
Sleeper415
Car: 240sx
Man im trippin balls right know i just got it running i have been doing my swap for about 5 months(not my falt a lot of things happend) and i just got it on the road.
i think i do have a stock oil tank catcher thing cuz everyhtings stockin the engine besides the FMIC.
I just dont know what to do????
is there anything i can do to stop it ??
otterman
sdwyzs14 wrote:pull it and check for play in the shaft and all that
If for some reason you don't want to do that, at least take off the intake and o2housing and see what you can see/feel.
Sleeper415
Car: 240sx
What will i be looking for exactlly?? OIL??
otterman
Reach in and see if theres oil inside the turbo. Try pulling on the spindal and see if there's any play in it. Play = bad. oil = worse
Sleeper415
Car: 240sx
i know ur probably going to laugh at me but whats a spindal? is it the fan looking thing?
otterman
lol yeah the fan looking thing. Don't worry, we all gotta learn some how.
Sleeper415
Car: 240sx
thankx man. hum well before i put it in i could spin it with my finger it was a lil rough but i could do it ima check that out right know and ill let u know
Sleeper415
Car: 240sx
I just noticed i got to take off my turbo extender and down pipe to check that out so ill do it tomorrow any other day i wouldnt care about working on my car but im beat right now.
But if it has play like u sed then its through and if ther is oil on it its also through dam i feel this is not going to be good.
If thats the case do u know wher i can get a a turbo for a good price???
rb20det_pwr
Car: skyline hcr32
take off the intake side (front) not the exhaust side..
jr_ss
Car: 95' S14
To me it sounds like the oil seals in your turbo are shot. You can have bad seals and no shaft play... Either way, you're going to need to replace the turbo or rebuild it..
Sleeper415
Car: 240sx
ok my boy had told me the same thing f**k i just love my ride and i hate to see it in my garage and not on the road u know. i dont know how to rebuild it i know that much.
so my only option is to get a new/other turbo. ok....i have to go with an upgrade cuz if im going to get another turbo why wast money on another stock T25. i know the next step up is a T28 or what, i need options cuz i really dont know what to do?
if i do go with another turbo what do i need with it as far as the whole top munt thing goes. im i going to be able to keep my turbo extender and down pipe or whats going to happen cuz im lost with what i need wastgate header
Logan76
Car: Junk
a T28 should mount right up to your stock T25 manifold. and you should be able to keep your downpipe, and do you mean an external wastegate?
Sleeper415
Car: 240sx
i guess an external wastgate cuz its stock so im not really sure.
jr_ss
Car: 95' S14
A T28, Gt28rs, or Gt2871r will all bolt up if you get the T2 foot print. I believe that the T28 from an S15 is the same as the Gt28rs, both good for about 275rwhp. If you want to keep it lightly modded, opt for the T28 size turbos, bolt on, might have to modify your coolant and oil lines a bit but, good power upgrade over a T25.. Good luck man
Sleeper415
Car: 240sx
thanx man thanx to everyone that relpyed to my thread im not done yet if i end up getting that T28 turbo i know it bolt on and u also sed i need modify myoil line and coolint lines but i dont know how to do that NEED HELP if any one can help thanx.
jr_ss
Car: 95' S14
I'm not saying that you have too, but there is a chance you will. Just buy SSlines and you have nothing to worry about...
S13FASTBACKSR
bro like i said before stop freaking out just give it about a week and see if it goes away..if it doesnt then you can replace your turbo..by the way when your turbo seals go bad you will usually get a ton of white smoke coming out of your exhaust when you come to a stop
jr_ss
Car: 95' S14
S13FASTBACKSR wrote:bro like i said before stop freaking out just give it about a week and see if it goes away..if it doesnt then you can replace your turbo..by the way when your turbo seals go bad you will usually get a ton of white smoke coming out of your exhaust when you come to a stop
That depends on which side seal goes bad. Sounds like the compressor side did, that's why he's got oil coming out of the BOV...
Sleeper415
Car: 240sx
i dont know what side its from but its not shoting out any smoke
S13FASTBACKSR
true to which side of the turbo goes bad but im saying from experience this has happened to me before with rebuilt turbo..same to my friend ...it happened for about a week and went away
Sleeper415
Car: 240sx
the only reason why i dont want to keep driving it is because if it is mest up and i do drive i dont want anything else getting mest up.
its just a wierd as* problem cuz my turbo sounds good just that oil leak and for some reason i dont think my blow off valve is working properly it sounds like the noise is coming out of my intake its heka wierd i had it in nutral and then i rev it up while i block the vacum line on one side and i put a rubber glove on the other side and the rubber glove inflates a lil but not a lot not even like nomal hand size so i dont know
S13FASTBACKSR
you put a rubber glove on the bov? is that what you mean? its not going to blow the whole glove up ...it sounds right...by the way is it a lot of oil or a little?
Sleeper415
Car: 240sx
its not a lot in was like 3 or four drops out of my BOV and a lil on the inner cooler pipe its not a lot though
jr_ss
Car: 95' S14
Sleeper415 wrote:its not a lot in was like 3 or four drops out of my BOV and a lil on the inner cooler pipe its not a lot though
If it's dripping out of the BOV, it's enough oil to say that the seal is bad... Oily residue in the piping is alright, but if it's dripping that's a no go situation..
Sleeper415
Car: 240sx
ok so my only option is to go with a gt28rs or a gt2871r .....the thing is that ima lil tight on cash and my limite on spending money for a turbo is $400 and under if i can find something good for that low.
im looking up rebuilt/remanufactured turbos and i found a T3 for $330 but i dont know how that goes as far as my set up. i need help and advice and im thanking everyone thats responding to my thread thats the web site of the T3
http://www.gpopshop.com/garrettturbos.html
S13FASTBACKSR
or you have an option of just waiting a few more days to see if it goes away..im not saying im right and you guys are wrong, im just saying to wait a few more days..drive it around put some distance on it and it may go away..im saying all of this because this happened to me and my friend and it went away and everything is fine and im also saying this to possibly save you some money since you are tight on cash right now
Sleeper415
Car: 240sx
it dosnt sound like a bad idea but will i be risking anything by driving it around like it is????
