Big problem, not much time..
S14Life
Car: b5 s4 stage 3, 2001 pathfinder, 91 s10
I have a later S13 blacktop motor. I have my engine in my car and everything is hooked up and the wiring is done, but there is a problem. I have power to my injectors but no injector pulse. I have power to the coils but no spark.. also the coil closest to the front of the motor is hot and the rest are cold and all the idiot lights in the car will stay on even with the key out. Ideas?
Any and all help is greatly appreciated
-Chris
sportbikedude
i had a problem kinda like yours. the plug that plugs into the computer was messed up. somehow the wires were in the wrong spot in the plug. find a printout of the plug and cross it with your plug. i bet some of the wires are in the wrong place.
S14Life
Oh great, do you have a diagram? Or do you know if the SR20DE plug is the same?
S14Life
Also my ECU number is J7.. did I even get the right ECU?
S14Life
bump
slow s13
Car: cars, photo, music
you have the right ecu as long as you have the wiring harness for the later balck top SR. 95-97 iirc if you look around you should be able to find the correct pinout and cross check it.
S14Life
Yeah I found it, but I gotta wait till tomorrow to do anything.
http://sr20det.nismo.org/srtech.htm
If anyone else needs it~
