what do you mean measure them? why would i measure them? like for what? sorry i know its a dumb question and its probably obvious but i'm knew and only my coupe since july 4, this year. and i've only had to change rims, intake, exhaust, battery relocation. but nothing dealing with suspension..so yea why would i need to change the outter ones as well?spank044 wrote: If you do both then remove the old one and measure it for total overall length. Then assemble the new tie rods with anti-seize and put it in the car.
ok lets do this first, order new inner and outer tie rods and 2 tie rod boots. I got wicked tuning tie rods for 120 shipped and they are thick and beefy. The inner tie rod is the long bar the connects to the steering rack. The outer tie rod is the thick smaller piece. What he means by measuring it is you take the good tie rod out and make each peice just as long. The outer tie rod screws into the inner tie rod, know what I mean?costa_rican13 wrote:what do you mean measure them? why would i measure them? like for what? sorry i know its a dumb question and its probably obvious but i'm knew and only my coupe since july 4, this year. and i've only had to change rims, intake, exhaust, battery relocation. but nothing dealing with suspension..so yea why would i need to change the outter ones as well?
i know they're too big. i have 17" rims, and i told the guy when i bought my rims, i wanted the smallest tire i could get but he gave me this tire that was like 2 inches thick from the lip of the rim. i think they're a 215/40(45) or something like that. i can't remember at the moment, plus my car is at my house and i'm staying at my grandma's house cause my dad is in missouri. but i wanted this size 205/40. its like an 1" from the lip of the rim.so yea. and the polish on the frame. thats not polish. its this white powder paint stuff that came off the road when the roads iced over on monday. but its not paint though but its like thick white dust or something. i don't know. i've never seen it before until nowspank044 wrote:Plus your tires are too big. In the 4th picture down it looks like the edge of the frame rail is polished. It might be a glare, but it looks polished to me. What size tires do you have?
ok how do you take the inner tie rod off exactly? like does it just unscrew from the pivot ball joint thing? or do you gotta pull the ball joint thing out or what? cause i have no idea. and my dads friend is like "this will be easy. if we can take it off then we can put it back on!" i'm thinking oh my god this is gona take forever." do you guys think i should just get the factory rods off a salvage or actually buy new ones. cause i'm not really wanting to spend $300 -400, on rods but if i have to i will.. well if not i'm gona hit up a salvage yard this saturday coming up since i'm off work. and just got a check so i'm happy but just can't wait to get drive my baby again. she's depressed now and cold from sitting in the garage for the past 4 days...fuse=--action wrote:This should be an easy job for you. The hardest part is going to be getting that inner tie rod off. It will be stuck on there pretty well. I had a hard time with mine, but then again I'm not exactly a big dude.-fuse.
And here . Just cause it's my favorite holiday smiley.
