chrisagu28 »
https://forums.nicoclub.com/chrisagu28-u87125.html
Mon Nov 10, 2008 9:55 pm
Well today was kinda weird. I am hoping somebody can help me. More of a update and eliminating the normal problems. Last night when trying to start it, It would not start at all.... After checking the ecu it came out with code 11 which is crankshaft position sensor. Well after some research that night, I tried testing it today by taking out the distributor, I also moved the fuel rail to see if the injectors are firing and did the same with the spark plugs and wires.
After spinning it by hands, I hear a relay kick on, i see the injectors firing one at a time as well as the spark plugs spark as well. So I got fuel and spark so no worries there. I put it all back together and try to start the car, still no luck. Hours and hours of trying to figure something out. Sometimes it wants to start but yet sometimes its a no go. What is weird is, I moved the intake piping off so the throttle body was showing and at the same time I removed the plugs to see if there were wet and they are dry. I put them back in and start the car again. BAM! it starts out of no where. Of course with me flooring it. But it start and idled at 1700. It start to dip down and I was oh no. I gave it some gas and it would not go above 2500 and I remembered about the piping so the maf was not working right. so I let off the gas and it bounced around from 1400-1700 and it sounded a little bit like it was missing but yet my timing is not exactly set. But yet this is the first time it kept idle without it dying. I cut if off cause something was spraying in the engine bay, stupid hose camp on coolant came loose. It will not start again.
I was thinking it might be my timing, maf, intake, ecu, or tps. Sorry for the story but please help me out. I am running out of ideas.
But to sum it up, I got spark, fuel, compression, and air. But it will not start again.
Modified by chrisagu28 at 3:09 AM 11/11/2008
