Projex240 »
https://forums.nicoclub.com/projex240-u4020.html
Mon Nov 24, 2003 4:03 pm
Ok, thats what I was thinking. WHy go through the hassle of a totally custom project, when the max potential is so limited by a transmission. I have never headr that the rb trannys were weak, but if what someone said already was correct, then 35-400 isnt worth the money invested if you are just goin to have to replace and rebuild trannies. Not to mention that c4's and powerglides, and turbo 350-400's are not very streetable. You lose ALOT of top end with them. Thats why the only guys who run them are serious drag racers who dont car that theyve already hit their rev limiter at the 1/4 mile mark. I would maybe think of an OS giken set of gears instead. Or if you want to put big money into it. HKS makes a fully built semi-sequential transmission that uses no clutch. Its about 10,000. But then again...you guys sound serious about drag racing...so id go for it. ANother question. If you guys are so into dragging, then why not completely go rb26 and keep the AWD? that would be the best way to run good ET's
