BIG oil problem (HELP)
B-rad Smizzel
Car: 240sx se
just went to change my oil and the filter had no oil in it. now im freaking out bc i have a new ams crate engine and i hope i didnt mess it up what do you think it could b. i used only royal purple oil and fram oil filters
B-rad Smizzel
Car: 240sx se
and i just went out to check my oil feed line to my turbo and it was dry to
Chris28
Car: 92 s13 KA-T
Call up AMS and tell them this. How long has the engine been running? Does the AMS crate engine come with an oil pump?
DevilMB3017
I think the obvious question is...Do you have any oil in your motor or oil pan?
B-rad Smizzel
Car: 240sx se
DevilMB3017 wrote:I think the obvious question is...Do you have any oil in your motor or oil pan?
ya i check my oil all of time
B-rad Smizzel
Car: 240sx se
Chris28 wrote:Call up AMS and tell them this. How long has the engine been running? Does the AMS crate engine come with an oil pump?
i have to have oil pressure bc the engine didnt lock up and it ran just fine. i only have about 4k on my motor and put 1k or less with this problem. they come with a new oem oil pump
neverlift
I'd install an oil pressure gauge, if it has not had oil pressure something is ruined. Get an electric one from harbor freight 20 bux is worth being able to verify you have oil pressure. Yes I have one and yes it seems accurate...53psi cold oil 20ish at 650rpm on hot oil, cranks upwards of 70 when on it hard. But beyond that it will verify oil pressure! or if you dont mind risking oil in the cabin sunpro has em for 30 bux at autozone...
B-rad Smizzel
Car: 240sx se
it was a bad oil filter bc i put a new one on (dry) only for testing. than i left my oil feed line to my turbo off and started my car. oil came out the feed line than i took off my filter and it was full of oil. so i put the feed line back on let it idle to clean it all out. now im going to order up a oil pressure gauge
motoman399
Car: 98' wrecked (RHD coming soon) 240
fram oil filters suck!!
B-rad Smizzel
Car: 240sx se
motoman399 wrote:fram oil filters suck!!
after im done with this one im switching to K and N
kouki_hmongster
Car: Want 97 kouki
I'm surprise you didnt blow anything, maybe you didnt lube the rubber ring of the oil filter when you installed it. Good luck and hope it doesnt happen again. Shiiiit i'm running Dominator AMS oil and K&n filter, it makes oil change such a hassle w/ $$. i have a built motor myself and i would probably freak out like crazy to see no oil in filter. LOL
livinglegend2100
yea fram oil filters are complete junk. theyre basically just a conglomeration of cardboard on the inside. K&N is good. ive had really good luck with purolators myself
480sx
Car: 1996 Pearl White 240sx
Purolator, AMSOIL, or Mobile one. The purolator pure one gets my vote on 90 percent of builds, 'cheap' and awesome. AMSOIL is hardcore, and the mobile one works well too. I only use mobile one filters in a pinch. You pay for the name, although it is a quality filter.
baron_harkkonen
Car: 1993 Nissan 240SX, 2005 Honda Civic
royal purple has a problem of 'disappearing.' i've got a buddy that ran it in a 750 brute force, he heard knockin sounds, killed it and checked his oil: empty. far as a filter goes, i only trust WIX.
