Big oil leak, ruined alternater
olympusheights123
Car: 1992 300zx
Ok so i have this oil leak and its big. So much so that my alternater is drenched in it and now it doesnt work. Now im new here so i dont really know how to upload pics but its hard to tell where the leaks are coming from but it seems the power steering pump right above it might be the cause. Any ideas? Is this a common thing for 300zx's??
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Easiest way to upload pics is to upload them to PhotoBucket (free), copy the link for it, and paste it into an IMG tag on here.
Anyway, yes the power steering pump can leak, it isn't uncommon. The hoses themselves can also go bad and cause a leak. You could coat the alternator in oil from an actual oil leak too like from a bad valve cover gasket, but I don't think it would be enough to drench it.
olympusheights123
Car: 1992 300zx
Image Its not a realy good picture but the general area is just drenched in what looks like old lube/oil and the alternater is just covered in it. Its hard to tell where the leak is coming from
ThisIsSparTTa
Car: 91 300ZX TT 2+0
huge oil leak in the front probably = front main seal
olympusheights123
Car: 1992 300zx
Is the front main seal on the passenger side? Cause theres no leak on driver front side
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
No, the front main is on the crankshaft. Your High pressure power steering hose is most likely leaking. It's very common to fail of someone uses power steering fluid in the power steering system. You're only supposed to use ATF.
nexus08
Car: 1990 300ZX NA
Power steering leak is my guess too based on location.
t.mcginley.jr
1966 Ford Mustang
If you're mechanically inclined, Z1 sells new hoses and also rebuild kits for the PS pump. If it was the front main seal leaking the oil/grease buildup would probably be contained inside the timing belt covers. Other than the PS pump leaking, like I said the valve cover gaskets can leak oil onto basically the whole engine over time.
ThisIsSparTTa
Mine supposedly had a "bad" front main seal leak before I got it, and it found plenty of ways to escape the timing belt cover. The entire engine bay is a mess. Luckily with the engine actually getting pulled out next week I can finally clean more of this stuff up.
