lucky03602 »
https://forums.nicoclub.com/lucky03602-u20182.html
Fri Jan 23, 2009 1:52 pm
ill have to get a pic to prove it but i have a friend down the road that did something similar.
he has a 79 ford full size bronco frame with a ford 460 matched with a c6 transmission, 8" suspension lift.
for a body he mounted a d21 hardbody nissan pickup, he roughly had to make 9 inch "body" lift to clear the drivetran, also had to cut out and replace/move/mod the firewall a little bit.
the truck is sitting on 38x14.5x15 and look like little tires compared to the rest of the truck.
i was going to do pretty much what he did with his truck, but i was going to use a parts 240.
its really not hard to do if you know how to fab things.
ill see if he's around this weekend so i can take a pic.
