BIG maintenance on my ser(lots pictures)
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
americanlife
Car: 2005 Altima SER
2012 Infiniti G37
my 05 altima ser lowered recently and hitting on 125000miles, so i think it is the time to do some maintenance.
left outer tie rod broken
right outer tie rod worn out
inner tie rod both very loose
front sway bar links both loose
rear sway bar links both broken
front sway bar bushings worn out
rear sway bar bushings look ok
rear shock bushings both worn out
the oem lower control arms looks ok but need the new ones anyway because
it is lowered by eibach prokit springs
overall after the alignment, ride quality and handling improve a loooooot!
DrewH
Car: 2006 Altima SE R
2012 G37X
Nice work. I've tried to stay ahead of he curve on some of these things already. Do all this yourself?
americanlife
2012 Infiniti G37
DrewH wrote:Nice work. I've tried to stay ahead of he curve on some of these things already. Do all this yourself?
hired a guy used to work for local nissan dealer $140 cash
z06hellcat
Car: altima v6
great job! :)
06SE-R
Car: 2006 Altima SE-R
good job! I'm following right behind ya I'm at 123xxx I just recently checked a lot of the things listed above and they seem to be in good working order but, I'm sure it wouldn't hurt to replace em though :ohno: If you don't mind me asking how much did it cost you to replace all of those parts wise
Return to “3rd Generation Altima Sedan (2002-2006)”
