DrifterXRPS13 »
https://forums.nicoclub.com/drifterxrps13-u10091.html
Fri Feb 18, 2005 10:42 pm
so i just got my car back from the shop, they put a new water pump on it, fine and dandy, car's running nice again...that was tuesday, and today as i'm driving it's fine but as the day goes on it's gettin harder and harder to put the car into 1st gear. it takes some time to put it in there but it goes in.
day progresses, 1 gear is no longer able to go in and same with 2nd....3 hours ago, i lose 3rd, so now i'm driving around in just 4th and 5th gear, i was about half an hour away from home at my cousins house...or else i wouldn't be driving it...so i'm leaving from my cousins and 1st, 2nd,3rd, and 4th are not going in, only 5th and reverse, everytime i try to put it into gear it just makes a thud...when i try to put it in 1st, the car rolls forward, if i hold the gear and try to put it in first and just hold it there, the car starts moving, it's not in gear but it just starts to go, same with reverse, it won't go in but it starts rolling backward...
so now i'm on the highway an i'm in 5th doing 40 miles an hour while everyones flying by at 80 or so...get off the freeway and come to a red, it dies when i brake, now i figured out that i can put the car into any gear when the engines off, so i put it into first then start it up, the car just takes off, no brake, no gas, just clutch in, 1st gear and ignition, it just starts rolling, so i go and go through the gears until im in 5th, only problem is i can't downshift, so i'm just driving in 5th again the whole way home....i get to another redlight and the car dies again..so i turn it off, put it in 1st, start it up, this time with my foot on the brake, and it won't turn over, so i let off the brake a little and it starts and just jumps forward,again foot not on the gas pedal....so i finally make it home and i have to move some cars to park mine in the garage, when i get back in my car i have to drive around a coldasac and usually i can take that in 1st gear...i start the car in 2nd and it just goes all by itself, no gas it's probalby going 20 miles an hour around the coldasac, i lose some traction going around, so the rear end is kinda going out but not much, i come to my driveway, pull in real hard, start applying the brakes, the lights start to dim and the cars dieing again, and as soon as the car got in the garage i just killed it, and slammed the brakes on, put it in neutral and put the handbrake up, got out and slammed the door yelling all sorts of obsenities!!!!
i don't know what the crap is wrong with it now, it's like it's possessed, i'm at the end of my ropes with this car, if it's fooked, i'm gettin rid of it... please help? sorry for it being so long but i wanted you to know all the info.
thanks
