XoticImports »
https://forums.nicoclub.com/xoticimports-u30508.html
Sun Mar 25, 2007 5:20 pm
OK, I have just purchased a 92 240. I noticed that it felt a little slugish when compaired to my old 91 240. So i did a tune up. (new plugs, wires, filters, and a general inspection) I noticed that the distributor was set as far as possible to the retard direction. so i hooked up my timing light and found that the spark was 25deg. BTDC. so i set it to 20deg. BTDC and it was even slower. so i played with the timing and found that it ran best around 45-50deg. BTDC. I pulled off my valve cover to see if my camshafts were properly aligned. I found the lower timing chain to be one tooth off. I correctly set the cam timing, but i still have the same problem. runs like crap at stock timing (20deg.BTDC) and runs great around 50deg BTDC. WTF?????? Ive been scratching my head about this for a while. Any Ideas?
ps. I swapped the distributor out of my old 240 that ran fine and it did not help.
