Ajizzy »
https://forums.nicoclub.com/ajizzy-u122940.html
Fri Aug 28, 2009 3:42 pm
K... so i Have a 89 240sx ka24e sohc. it was a auto i swapped it it runs fine But the other night i was leaving work and i started my car then went to turn the lights on. all of a sudden the starter cut on ..... so i had to get home so i started the car then UN plugged the starter wire and the turn the lights on worked perfect all the way home.... this morning i go out to see what might of caused this and now wen i turn my lights on i have no marker lights, no tail, and only one headlight works. but if i press the brakes the brake lights come on, and if i turn the high beams on they work. oh and i check the fuse box under the dash im not getting power from two spots under there sooo can u help me out or what!!!!
