chefnee »
https://forums.nicoclub.com/chefnee-u266015.html
Fri Aug 06, 2021 1:56 pm
I had something like this affect my gas mileage. Sorry again, this conversation is a little dated, but still holds true. I had a couple of issues. One was the O2 sensors and the other was a fuel tube that connects from the fuel line to the engine. My symptoms were the check-engine light. They were all leading the performance of the fuel/air mix. One of the codes say running lean and another was saying running rich. I tried with aftermarket sensors, but the codes still came back. I then ordered OEM, replaced them, and the codes went away.
The second issue had to be immediately replaced. I was getting a very heavy gasoline smell. It was very bad when I applied pressure to the throttle during driving. It turns out that the fuel tube/fuel hose that connects the gas to the engine was damaged. I order a new one and replaced it.
After both fixes, I saw an improvement average of 18~19 MPG (prior) to 23~24 MPG (after fix).
