94_240sx wrote:
Idea is... You have more grip when caliper sits further away from the center.
Eh?
Usually when you up the size of the rotor like that, you're trying to disperse the heat more and keep temps down. A larger surface area from a larger rotor like that takes longer to heat up, keeping your pads from heat fading. However, on the rear you won't see that much advantage just because of how little the rear brakes do to stop the car.
Personally, if you're going to upgrade the rears, you're best bet is to use Z32 rear brakes. And it's not that big of a pain, you just need to do some research and make sure you have all the parts you need in advance before you start tearing into the rear.
The bare minimum should be:caliperdust shield/e brake backing platee brake assye brake cable (2+2 is slightly longer than a 2 seater Z, but you will still have to route it through the subframe)Z32 brake lines (SPL has the best deal on SS lines that will flawlessly mate the Z caliper to the 240 hardline)Z32 rotor (Heavy Throttle has these pre-drilled for 4 lug)
You don't NEED the aluminum upright as you can bolt all the Z stuff to. However, a word to the wise is to clean out the big hole that the long e brake pivot thingy slides through. The steel uprights tend to collect dirt and rust in that hole and if you don't clean it out good enough, your pivot becomes a press fit. One of mine will have to be cut out of the spindle because of that fact.
Skyline e-brake cables will bolt up to the stock 240 routing from what I understand, but because of the cost, I opted for Z 2+2 cables (I paid $20 for my pair)
And be ready to possibly replace the front e-brake cable for the handle. My car was a Jersey car originally and the salt had fused the rear cables to the front cable. I had to cut the old cables out and replace the front one. And that's not fun because it's riveted to the handle. Thankfully the new cable has a rivet already installed, but pressing it into shape can be a bit tricky.
In the end, I only did the rear upgrade for aesthetic reasons. Also, I did it to make 100% certain that the Z master cylinder was working with a full Z setup to ensure optimal fluid pumping. I think if you left the rears stock, the Z master cyilnder would still work fine in keeping the brakes from being touchy. If it's still acting kind of funny, just place a proportioning valve inline for the rear to turn the pressure down on them.
