Big BRAKE problems ... please help...
ZULU
Ok guys here it goes....
I just changed my rotors and pads a week ago.
On a S14 i put on
Brembo rotors and KVR carbon pads bleed the brakes with Motul 5.1
Anyways It seemed everything went great but I have a problem.
I cannot lock up the brakes.
and when I am at a full stop and i try I can press the brake pedal to the floor. I was thinking I have air in my system but I used two full blottles and bled it till clear fluid came out and no air... so i assume there is not air..
does anyone have some smart ideas ????
ZULU
P.S. I bled the brakes with teh car OFF ...and no ABS does the car have to be on to bleed the brakes ?
Hijacker
Car: '92 240sx Convertible
'94 F-150
no. the car should be off to bleed them. When you mentioned that the pedal goes to the floor, is the car on when that happens? the pedal only stiffens when the car is off.
ZULU
I can press it right into the floor with teh car on ... My old brakes never did this.... and they were super worn out and warped ...these new ones are giving me tons of headaches.... even with teh car off I can touch the floor.... any ideas ?
S13ChucKAT
Car: asd
yea, i have an idea, you have air in your brakes.. it will take a while dude, and use a rubber mallet to knock the calipers a bit, just bounce the hammer on the calipers, not slamming them, sometimes air gets lodged in parts..
crzycav86
Car: 93 Nissan 240SX KAT
When you bled the brakes, did you pay close attention to the master cylinder to make sure that it didn't empty? If not, you may have added air through that.
But it definitely seems like you have air in your brake system.
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
when im at the stop light i can also push the brake pedal to the floor (thats normal right?), but when im driving i never have been able to cause my brakes grab hard and my tires lock up b4 my brake pedal gets to the end of its travel.
i just put hawk hps pads all around with brembo blanks in front and old rear rotors.. bled fluid too..
max
Chingon
Car: 1991 and 1992 hatchbacks
brake pedal to the floor is never normal.
You have air in the system. Did you follow the right bleeding procedure?
