he's right. let's give it a rest, huh? I apologize to trpower7. Didn't mean to get you all hopped up.
Back to the subject. So far we all agree that he has a vacuum leak somewhere.
The best way to troubleshoot this is by the book. There is a picture in the repair manuals that shows all the ECCS components relating to exhaust and smog. In the Chilton's, the book shows a picture of each component and where it goes in the motor. It also shows numbers on the end of the vacuum fittings on each component. Follow each number and match it up with the same no. on the other component. The numbers are small so if you can't read a few, come back to them later.
At this point I'd replace all the vacuum hoses anyways (get silicone hoses and get that out of the way.)
There's also a thread posted on here for the AIV Valve. check the reeds inside if you haven't done so yet.
If you smell fuel, double check all the fuel lines, fuel filters including the one in the tank (very easy to ckeck), pressure regulator, and especially the injector O-rings.
JDM is the true path to performance!
[email protected]'89 NISSAN 240SX, '90 KA24E SOHC,5-spd conversion,'96 180sx turbo fuel pump,port & polished these:12v head (in/exh), MAF sensor (main inlet only), air filter adapter, throttle body, intake plenum, intake manifold, removed SCV valves (2nd butterflies) Injen intake, HKS SuperMega Flow Filter, HotShot Headers (w/ thermotec exh. wrap to cat-back exh. canister), custom 60mm straight exhaust (JDM), HKS Superlow Form Springs, KYB AGX shocks (adj.4/8), FR/RR strut bars, Nismo Chassis brace, Random Tech High Flow cat., custom 2.5" JDM style exhaust,HyperGround Wire System, Magnecor 8.5mm wires, Splitfire 3xPlatinum plugs, Nismo Radiator Cap (18psi/1.3bar), S13 VLSD, ENDLESS brake pads, Jun Lightweight Flywheel, Centerforce Dual Friction clutch,Optima Battery, Bomex body kit, about to be the 1st, FIRST! in the US with a JDM Ikeya Formula Complete body kit...
