gwilli3272 wrote:SteveTheTech, as a moderator you should know how a capacitor works. Since you obviously do not, then start taking notes.A CAP on an electrical system that is already over tasked is only going to get worse. There is no feasable way an electrical system that can not keep up with electrical current demand a cap is going to make it worse. You need to first get your electrical system up to par before you even think about adding a cap. A big 3 upgrade, a better battery, and a grounding kit you so desire, should 9 out of 10 times get the dimming issues solved. If not that is when you get a high output alternator. THE ONLY THING A CAP DOES IS STIFFEN THE VOLTAGE TO YOUR AUDIO SYSTEM, NOTHING MORE. I have no care as to your inputs on this, as I know that I am absolutely correct on this and you are dead wrong. As a moderator you should have known this and should not have advised someone to add a cap to their already limping electrical system.
I think Steve understands caps. On an electrical system once the CAP is charged then it will not add any additional demand except for its leakage current. When the electrical system has a sudden demand then it will give up its stored energy to the load. Super Caps are actually used on some experimental hybrid cars. On one for example there is a 100 hp gas engine and a 300-400 hp electric. When demand requires the Super Cap will discharge powering the electric motor for a very high performance car.
As far as lights dimming a couple of issues may be present such as a high resistive connection to (and or from as in ground) the lighting circuit. While a cap may help the solution is one often used on very high powered audio systems and that is a separate battery as someone already has pointed out. The trick is the battery works best closest to the load and that means possibly placing it in the trunk. Because of this you should select a battery that will not cause any issues due to leakage or one that will gas off. An isolator is a must.
The cable currently in use is probably plenty for the power cable to the new battery which can be fairly small depending on the need to run the audio system with the car off. Even on these systems a cap can be of benefit to the battery itself and also to the load being driven.
Perry
