Sardonic »
https://forums.nicoclub.com/sardonic-u120227.html
Mon Sep 21, 2009 5:06 am
Nothing ignorant about it, can't learn without asking. That's what I'm doing!Allegedly, to compensate for the extra draw of demanding audio systems, this mod is done to increase the ease of the flow of power. If I'm explaining it correctly, it's allowing the power to flow more freely.
So you upgrade the size of the alternator to battery wire, you ground the battery to the chassis and you ground the engine to the chassis. Better ground, easier power flow, less impact from the demand of big systems.
Probably won't notice a damn thing on newer cars and probably won't make a difference since most new cars are already multi-point grounded but I'm trying it anyway. It makes as much sense as a capacitor. I think the only real upgrade to aid a demanding system is a higher output alternator but I'm trying the DIY and less expensive mods first.
So far, I've done the grounding, the optima yellow top and the 2 farad cap. The lights dimming from the high demand has decreased and even though the volts drop, they don't bottom out and dance all over the place. Didn't completely cure the issue but it "seems" to have lessened it.
The yellow top was a last minute change because I fought the concept tooth and nail. Until I found out it was a deep cycle and specifically designed for the abuse a high power system will throw at it. Doesn't give any more power, just makes the pull a little easier to recover from.
The only thing I've noticed about the grounding is that when I'm not going fast enough in a gear, I no longer have that little reminder nudge that the car would do. It's smoother. Does this come from the extra grounding? Who knows? It's not impactful enough to say definitively. The pretty blue wires look good under the hood though, that's worth the price. (they were free).
Biggest improvement to sound quality from my gear was dead on matching the head unit volts to the amp volts. That was a measurable improvement. Everthing else is just an experiment.
Thoughts and help appreciated.
