fiveliterbeater wrote:i thought i read somewhere here to never add fuel additives to our VK motors.
Correct, normally, it is not recommended to use an additive all the time. Or too often.
However, for the occasional injector cleaning (doing it a couple of tankfuls of gas just before an oil change) is very helpful. The symptoms where I would do it are: stumbling, excessive pinging when accelerating - due to carbon build-up.
Only once (or at most twice - if the first one does not cure the engine improper behavior) a session every oil change interval - which, for me, is 3750 miles.
Separately: using ISOHEET (not regular HEET) occasionally - maybe every third to fourth tank full - to remove water content from the gasoline, is a good thing! This is not an additive per se, just isopropyl alcohol based water remover.
Z
