BG ATF additive
66mgb
Car: 1992 Q45 Modified w/ NICO Goodness
Anyone have experience w/ BG ATF additive? Just curious if this should be used w/ the Q45 maintenance regime.
Thanks!
Q45tech
It is similar to MOA/111 a zinc extreme pressure additive and mild seal sweller and gasket lubricant primarily for use AFTER a Quick Clean for AT flush and after a machine or otherwise total ATF change.
Returns some of the flexability that the Quick Clean solvents strip away.
It won't cure a bad or misbehaving AT.
It appears to increase thicken the viscosity of ATF a tiny bit.
